Notchy shift to 3rd
When shifting to 3rd most every time feels like it snicks a tooth on the gear. All other shifts are fine and even 3rd is not a grind just kinda clicks past a tooth. as if you can feel it hit 1 tooth on the the way into gear.
I bought the car (03) used bout 3 months ago from a dealer. Had 17k miles looks like new, but the warranty has expired. let it go or have it checked out?
charlie
charlie
my new 2006 model is similar. 3rd is notchy, one time i didn't push it in 3rd far enough and it popped out when i let the clutch out. i think its just a quirk.
maybe you should change out the tranny fluid to some of the slicker stuff. GM synchromesh or Redline.
As for your situation, don't lose any sleep over it. It's not a "problem" unless it doesn't stay in gear or if it grinds all the time no matter now you shift it.
Originally Posted by randoggz,Mar 7 2006, 10:29 AM
I have the same problem but it only happens when i shift to 3rd and i'm in vtec. has this happened to anyone?
Originally Posted by xviper,Mar 7 2006, 11:53 AM
This is not really a mechanical "problem". You are likely rushing the shift and pushing the stick through the "diagonal" (cutting the corner). The 2 to 3 shift has a distinct directional change in the stick movement. This can still be done rapidly but most don't make a concerted effort to incorporate this in the shift.
-gp
I have the same 3rd. gear scratch, just a little "tick" as it goes in. Every shift has a 2-step feel to me (first being synchro contact, second being actual gear engagement), with 3rd and 6th being most noticeable. If I slow my shifts or shift at higher RPMs everything works quite nicely, it is the cold tranny, low RPM shifts that are clunky.
lunardeathgod
Jun 19, 2012 03:47 AM
