Notchy shifting
Old Jan 15, 2012 | 06:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by lilboibounce
If your a Ap1 then try to regrease the shifters u-joint with high temp grease. Plus do a tranny service with redline mtl. That should do the trick.
This sounds good on paper, but it is not the cause of notchy or difficult shifting in this car. AP1 and AP2 are Identical when it comes to shifters. But thats not the problem.
Dirty clutch fluid, poor rod adjutment, and a rusted input spline will always be the number one causes.
Old Jan 15, 2012 | 02:03 PM
Kyushin's Avatar
Banned
If your a Ap1 then try to regrease the shifters u-joint with high temp grease. Plus do a tranny service with redline mtl. That should do the trick. ps if you did do a tranny service also do the diff its just good habit because they're both have moving components.
The U joints, I dont think I have ever actually greased those... were only done when the clutch was installed and thats been a really long time.
Old Jan 15, 2012 | 03:57 PM
lilboibounce's Avatar
True, but there's always variables when it comes to notchy shifting.
Old Mar 5, 2012 | 12:26 AM
05thumper's Avatar
How do you resolve the rusted spline issue? Obviously the tranny has to come off. Is this AP1 specific? Can it be removed with a wire brush then greased? How to prevent from returning?
Old Mar 5, 2012 | 04:25 AM
MegaTRon's Avatar
Originally Posted by Billman250' timestamp='1326641867' post='21318750
[quote name='lilboibounce' timestamp='1326636638' post='21318651']
[/quote]
Do not argue with Billman. he is the man. lol
Old Mar 5, 2012 | 04:35 AM
Billman250's Avatar
Top Answer: 1
Yes there are variables, greasing the shifter gives you about a 1% chance of fixing notchy shifting.
The s2k comes with no grease on the disc spline from the factory. If your clutch is original, and has many years on it, you can bet the bank you have a rusted spline.
Clean with a wire brush, and use a high-adhesive grease like Valvoline Cerulean. You can expect over 100k miles of wonderful, brand-new-car-like shifting.
Old Mar 6, 2012 | 07:45 PM
billiardboy904's Avatar
Is there anyway to get to the spline without dropping the tranny?
Old Mar 7, 2012 | 12:12 AM
Billman250's Avatar
Top Answer: 1
No.
Old Mar 7, 2012 | 12:25 AM
ahrmike's Avatar
billman, do you ever adjust the master cylinder? if so, do you think theres a minimum requirement of pedal travel?
Old Feb 29, 2020 | 08:14 PM
hardjoe's Avatar
anyone can help reply to this?
i am having some notchy feel on my ap1.5
