now low compression.....
Old Feb 16, 2007 | 02:04 PM
runutzzzzz's Avatar
Default now low compression.....
My friends S2K. What happened?
Thanks
Old Feb 16, 2007 | 06:53 PM
oakfloor's Avatar
Originally Posted by runutzzzzz,Feb 16 2007, 03:04 PM
My friend overheated is 04 S2K. We took the head it was warped so we had it milled. New headgasket new head bolts... We did a leakdown test and it read low. It was leaking though the exhaust valves and intake valves!!! What happened?
Thanks
Warped , or burned valves. out of adjustment?
Old Feb 17, 2007 | 11:30 AM
gew5333's Avatar
When the head warps there is a good chance the valves don't seat properly anymore. If the machine shop surfaced the head they should have checked this. Ask them if they vacuum checked the valves. If they checked everything properly maybe the valve adjustment is being performed incorrectly.
Old Feb 18, 2007 | 06:49 PM
runutzzzzz's Avatar
So what do I need to do? Do we need to get new valves?
Old Feb 19, 2007 | 05:32 AM
snakeeater's Avatar
You need to find out why the leakdown test results are bad. Repeat the test to be sure. Could be a bad mill job on the head or maybe the deck is warped as well. Maybe the head gasket wasn't installed & torqued correctly. Maybe the valves are bent. Lot of 'maybe's. Don't just throw parts at the problem, it's too expensive on this engine.
gaxiola805
Apr 15, 2016 02:58 PM
cmc600rr
Nov 17, 2015 04:11 AM
the fan
Jun 18, 2009 08:04 PM
lucky77
May 6, 2008 12:34 PM
BlownAP
Jul 29, 2007 09:25 PM
