Valve Tolerance Issue
Old Nov 16, 2015 | 02:03 PM
cmc600rr's Avatar
Default Valve Tolerance Issue
Hey guys,
2003 s2k, about 35k miles ago I had the cylinder head off the car to have valves replaced due to a money shift. Rebult at a reputable machine shop using oem components.
Ever since then I've had my valve clearances tighten up requiring a valve adjustment. This happens far more often than it should.
Why is this happening? Valves wearing into the head? Valves stretching? Should I pull the head back off to investigate?
Old Nov 16, 2015 | 02:15 PM
MM3Kwolik's Avatar
Yes. The machine shop didn't know what they were doing and the valves are wearing into the head/seats. No choice but to pull the head again for a proper rebuild. You don't want to leave it much longer that's for sure.
Old Nov 16, 2015 | 02:29 PM
cmc600rr's Avatar
Since it may be wearing into the head, would it even be worth it to try and rebuild this one? Possibly a better idea to look for a good used one?
Old Nov 17, 2015 | 04:11 AM
Slowcrash_101's Avatar
Luckily the seats can be replaced, so it's not a huge deal, the person that responded to your original post can actually fix it right.
Silver_Bullet_S
Oct 6, 2018 01:15 AM
surfer_crx
Sep 23, 2013 09:36 PM
macprotege5
Feb 18, 2009 07:50 PM
runutzzzzz
Feb 19, 2007 05:32 AM
