NRG SHORT HUB INSTALL HELP!
Old Jul 5, 2012 | 07:26 AM
vtec4life57's Avatar
Default NRG SHORT HUB INSTALL HELP!
SO LOOKING TO INSTALL MY PERSONAL 350MM NEO GRINTA NRG SHORT HUB AND NRG 2.5 RELEASE. I KNOW I HAVE TO REMOVE THE SRS REEL. BUT I DO NOT WANT THE SRS LIGHT ON! I SEARCHED INTO THE WEEEE! HOURS LAST NIGHT AND COULD NOT FIND A DEFINETE ANSWER ON HOW TO MAKE AND USE THE SRS FIX! I DO KNOW HOW TO RESET IT IF IT DOES COME ON AFTER I REINSTALL THE BATTERY.. I JUST WANT TO KNOW WHAT I DO WITH THE REEL CONNECTOR IF I JUST LOOP A WIRE OR WHAT WHEN I REMOVE THE SRS REEL.. THANKS AND SORRY FOR ALL CAPS USING THE POS WORK COMPUTER
Old Jul 5, 2012 | 09:53 AM
nrg short hub remove srs reel? and if so how do i use the srs fix?
Old Aug 8, 2013 | 04:18 AM
axus19's Avatar
if its the SRK-130H yes need to remove the reel, but if its the SRK-131H you dont.
Old Aug 8, 2013 | 09:53 AM
LiDo711's Avatar
Yeah there're 2 versions, the cheaper one remove the SRS reel and the horn doesn't work unless you mod a horn contact behind the hub. The 2nd version cost about $50 more comes with SRS resistor bypass, work with horn with SRS reel in place etc.
Cost more but worth it
GatoRx
Mar 6, 2017 05:21 PM
FTW.inc
Jun 4, 2010 02:41 PM
S2_PHENOMENON
Sep 27, 2008 03:22 PM
6speedftw
May 25, 2007 10:15 PM
i</3speedbumps.
Dec 17, 2006 10:36 PM
