Sponsored by: CARiD
Momo Hub with an NRG Thin Quick Release
Old Feb 10, 2010 | 04:58 AM
FTW.inc's Avatar
Default Momo Hub with an NRG Thin Quick Release
I just ordered the momo hub to go with my NRG thin quick release, from what I read previously on here everything is supposed to work together, and I should be able to avoid the airbag light and still have a functioning horn. As far as the install process goes, and the wiring to make that all work, can anyone point me in the right direction to a thread on the install process? I tried searching but couldn't come up with the exact process. Thanks.
Old Feb 11, 2010 | 04:22 AM
FTW.inc's Avatar
bump
Old Feb 11, 2010 | 10:45 AM
Chow-bot's Avatar
look in the FAQ for install
Old Jun 4, 2010 | 12:20 PM
FTW.inc's Avatar
bump, didn't find anything in the faq
Old Jun 4, 2010 | 12:42 PM
Chow-bot's Avatar
you just realize now?
plus you must have not looked in the right FAQ
https://www.s2ki.com/forums/index.php?showtopic=548714
scroll down to interior
Old Jun 4, 2010 | 01:07 PM
kids2k04's Avatar
i looked there.. there isnt any pics.. i gotthe nrg setup and im having an issue to install it...
Old Jun 4, 2010 | 01:29 PM
Chow-bot's Avatar
then google it,
its a fairly simple install, what are you having issues with?
Old Jun 4, 2010 | 02:41 PM
CapoArgentino's Avatar
Banned
You need to (After removing the OEM steering wheel itself):
* Remove the SRS reel
* Using a flexible piece of metal, create a horn contact (I used a feeler gauge plate, common sense is key here, lots of ways of doing this)
* Install the hub (Should have slots that line up w/ the turn signal toggle wheel.
* Install the column hub center bolt
* Connect the horn wires from the hub to the quick release base
* Bolt on the quick release base to the hub (6 hex screws. Try not to crush the horn cables that will be sandwiched together between the hub and quick release base)
That does it for the hub and quick release. Very simple. For the airbag SRS light defeat, I'll let you search for it
Acethriller
Mar 17, 2016 10:21 AM
benw.17
Sep 22, 2012 08:37 PM
NoRegrets78
Jul 1, 2011 03:50 AM
S2_PHENOMENON
Sep 27, 2008 03:22 PM
regmilla
Sep 29, 2005 05:27 PM
