NSX caliper on S2000 ?
Old Sep 4, 2003 | 05:54 AM
demonderrick's Avatar
Default NSX caliper on S2000 ?
someone said that NSX caliper will fit S2000...
it is 4 piston caliper... huh... what do you guys think?
Old Sep 4, 2003 | 06:01 AM
SC-SUZUKA's Avatar
demonderrick, I was told that the calipers will fit. I want them too.
Chris C.
Old Sep 4, 2003 | 06:26 AM
Bass's Avatar
don't know - What's up Derrick
Old Sep 4, 2003 | 06:36 AM
nothin much...
just looking for some new toys to play with..
and SC-Suzuka, do you mind to tell me who told you that? I am about to do it... and I don't wanna waste any money on it..
Old Sep 4, 2003 | 08:38 AM
CRX7's Avatar
NSX caliper is a two piston caliper and is a direct bolt on for the ITR, and has been used on a number of other civics integras with some modifications. I've got some links to the write-ups on the hybrid site at home, I'll post them up when I get a chance.
Also, the Legend GS is mostly the same caliper as the NSX. A twin piston caliper, but with larger pistons. Doesn't have the cooling fins and the NSX logo on it though, but they can be had for much much cheaper. I almost went this route with my CRX, but then want witht the fastbrakes kit.
Old Sep 4, 2003 | 09:50 PM
so, I assume no one on the board has done it...
huh... should I be a pioneer?
Old Sep 5, 2003 | 12:06 AM
CMiS2K's Avatar
please be the pioneer!!! go for it man!
Old Sep 5, 2003 | 12:47 AM
4IGS2000's Avatar
Spammer
im not sure if the braking system will be balanced with the S2000. The NSX is rear wheel drive and mid/rear engine, as the S2000 is rear wheel drive and front engine. The brakes may have different pistons that are built specifically for the NSX. Best way to find out if these kits match, is research an aftermarket brake company i.e. brembo, as see if they use the same calipers as the S2000.
Old Sep 5, 2003 | 12:51 AM
vapors2k's Avatar
don't waste your time buddy, they are heavy casted iron calipers (like stock). You're better off looking at aftermarket kits out there that reduce weight and improve pedal feel...ie a properly engineer'd 4 pot setup
Old Sep 5, 2003 | 12:52 AM
vapors2k's Avatar
[QUOTE]Originally posted by 4IGS2000
[B]im not sure if the braking system will be balanced with the S2000.
