nub on transmission
Old Feb 28, 2013 | 06:15 PM
evox's Avatar
Default nub on transmission
Hey yall.
I have a f20c going into my homebuilt lotus 7 replica and had a question about the transmission. I've never worked on or studied an s2000 driveline in its natural habitat.
Is this nub (see picture) ok to remove? it causes a slight clearance issue. Is it used for anything on the s2000?
here is the car its going into
Old Feb 28, 2013 | 07:41 PM
MM3Kwolik's Avatar
If that's the spot that I think it is, it's only purpose is served when separating the halves of the transmission casing. It is a pry location to help leverage the two halves apart from each other and as far as I know, it is completely solid and the casing behind it is just as thick as everywhere else. I see no reason for you to not be able to cut/grind it off.
Old Mar 1, 2013 | 09:42 AM
SpitfireS's Avatar
All I wanna know is: why do you carry a bicycle at the back of the car?
Old Mar 1, 2013 | 11:37 AM
s2000ellier's Avatar
because racecar
Old Mar 1, 2013 | 02:28 PM
CrAzYNeSs's Avatar
Member
Originally Posted by s2000ellier
because racecar
Old Mar 1, 2013 | 05:24 PM
Slows2k's Avatar
Grind it down, weld it up if needed, Because racecar.
Old Mar 1, 2013 | 09:05 PM
realblag's Avatar
Originally Posted by Slows2k
Grind it down, weld it up if needed.
This applies to the bicycle as well.
Old Mar 4, 2013 | 08:58 PM
evox's Avatar
For stunts.
S2000=Love4life
37
Aug 14, 2018 06:33 AM
S2000=Love4life
Automotive builds
22
May 17, 2015 04:18 PM
rdhunterx
Sep 23, 2012 09:58 PM
slackfaster
Aug 2, 2009 10:19 AM
