o2 sensor ?
Old Jun 1, 2011 | 11:51 AM
tmkpres's Avatar
Default o2 sensor ?
So I tried searching for my answer here and google but couldn't find what I was looking for.
My qustion, is it bad to touch the o2 sensor with your bare hand. I don't know if I messed mine up by trying to rub off a mark that was on my o2 sensor.
There are 2 factors.
1. I rubbed the sensor to try and get a mark off.
2. I just installed a header back system (I was running a test pipe with another exhaust) with a different anti fouler (same setup but with steel wool in between the two plugs). Would of used mine but I spot welded it onto my test pipe.
I guess process of elimination is in order
1. A new fouler; like my old set up (NEVER threw a code).
2. Try and new sensor (expensive to find out mine is still good)
Thanks in advanced.
Old Jun 1, 2011 | 12:16 PM
whippets2k's Avatar
I doubt that touching the sensor would really mess anything up. As long as you aren't clogging up the little "fins" then I wouldn't worry about it.
Any oils on your finger would get burnt up pretty fast due to exhaust gases.
Old Jun 1, 2011 | 12:38 PM
benw.17's Avatar
I almost positive touch the sensor does not hurrt it at all because i touched mine and never had any code problems.
Old Jun 4, 2011 | 03:09 AM
Croc's Avatar
the sensing part itself is inside the housing - so you can't really touch it.
Broman_The_Swede
Jul 17, 2016 11:58 PM
RedSunS2K
Sep 18, 2012 02:00 PM
fallen612
Apr 21, 2011 07:13 PM
F20C_S2k
Mar 26, 2009 12:44 PM
TheCarGuy2021
Jun 19, 2007 02:07 PM
