O2 sensor
Old Nov 14, 2011 | 02:39 PM
starchland's Avatar
Try ngk
Old Nov 15, 2011 | 12:56 PM
abnormals2k's Avatar
The code is P0135: o2 sensor heater circuit
I, however, have a test pipe with an 02 sensor it it, but i do not have the long spacer that some people use. Does that matter?
Old Nov 15, 2011 | 01:10 PM
s2000maniac's Avatar
yes you need that spacer. that's probably why your check engine light is on. BTW is it BANK 1 sensor 1 or sensor 2?
Old Nov 15, 2011 | 01:25 PM
Bank 1
Old Nov 15, 2011 | 05:33 PM
starchland's Avatar
from my experience the bosch ones dont work well on some hondas. The heater circuit basically preheats the o2 sensor to get better readings I believe, which should throw a different code than an o2 sensor that is out of spec. When does the code pop up? right after 3 bars? that could tell you alot. Was it an s2k specific sensor?
Old Nov 15, 2011 | 06:41 PM
S2k specific, dont know the bars. But im also gonna give this spacer a shot
Old Nov 15, 2011 | 09:23 PM
Croc's Avatar
another thing - if you bought your Bosch from ebay - a lot of fake ones over there.
the real Bosch can't cost 40$.
even if it's genuine - you might got damaged one.
or there is a electrical problem with heater circuit...
Old Nov 15, 2011 | 10:07 PM
not from ebay, from a fellow S2KI member...
Old Nov 16, 2011 | 04:51 AM
AngryTurtle's Avatar
No it is completely unrelated. It should go off after just a few starts if it is fixed.
Old Nov 16, 2011 | 09:25 AM
davidc1's Avatar
Yeah, I've never seen the Bosche go for cheap.
But, the direct plug in replacements from Delphi, Walker and Denso work fine.
I've gotten them all for great pricing from www.oxygensensors.com
