o2 sensor question on 06+ MY
I've done some googling and havent really found an answer. So I am pretty sure my o2 sensor is damaged (cat comb came dislodged and dented it, so I gutted the cat and did a cel fix, still didnt fix the p0420, so I put on my berk headerback and same result). Another member is wanting to sell his o2 sensor off his 2004 S2000, but I notice that the part numbers are different for 06 and up.
Thanks Bill! It's got a considerable dent in it, where the outter metal casing is touching the inner metal on the head of the sensor, but if the you think the sensor is still viable I trust your judgement. The Berk has a bung on it about two inches long, and the defoulers are slightly shorter. I might try putting one of the defoulers on and see if that makes any difference. P0420 is the only code being thrown
You happen to know the thread pitch? Found this M18 x 1.5...not sure if that's right
http://www.amazon.com/Degree-Angled-.../dp/B00B1U6I54
