o2 sensor question on 06+ MY
Old Feb 9, 2015 | 10:39 AM
RedCelica's Avatar
Default o2 sensor question on 06+ MY
I've done some googling and havent really found an answer. So I am pretty sure my o2 sensor is damaged (cat comb came dislodged and dented it, so I gutted the cat and did a cel fix, still didnt fix the p0420, so I put on my berk headerback and same result). Another member is wanting to sell his o2 sensor off his 2004 S2000, but I notice that the part numbers are different for 06 and up.
Old Feb 9, 2015 | 12:01 PM
afzan's Avatar
Do you have flash pro? I believe you can disable the secondary o2 (the one in the cat/TP)
Old Feb 9, 2015 | 01:06 PM
RedCelica's Avatar
I dont unfortunately. Stock ECU
Old Feb 9, 2015 | 01:36 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you have a code P420, then you don't need a new o2 sensor.
You need to try different angles/configurations with your o2 spacers.
Old Feb 9, 2015 | 05:35 PM
RedCelica's Avatar
Thanks Bill! It's got a considerable dent in it, where the outter metal casing is touching the inner metal on the head of the sensor, but if the you think the sensor is still viable I trust your judgement. The Berk has a bung on it about two inches long, and the defoulers are slightly shorter. I might try putting one of the defoulers on and see if that makes any difference. P0420 is the only code being thrown
Old Feb 10, 2015 | 05:11 AM
Billman250's Avatar
Top Answer: 1
You need a right angle spacer, point it towards the front of the car.
Even with the outer cover broken on the o2, it will still function normally.
Guaranteed
Old Feb 23, 2015 | 04:47 AM
RedCelica's Avatar
one defouler added and still threw a code. Now I have two on but need to test drive. If this doesn't work I'll look for the angle spacer. Thanks Bill! See you soon brotha!
Old Feb 23, 2015 | 06:13 AM
Billman250's Avatar
Top Answer: 1
You can put 4 spacers on it won't work. Get the right angle spacer.
Yes see you soon
Old Feb 23, 2015 | 04:21 PM
RedCelica's Avatar
You happen to know the thread pitch? Found this M18 x 1.5...not sure if that's right
http://www.amazon.com/Degree-Angled-.../dp/B00B1U6I54
Old Mar 2, 2015 | 04:27 PM
RedCelica's Avatar
rescanned again tonight and did in fact see a p0137 to accompany the p0420. Pretty sure that means I need an new o2 doesnt it
