OBD-II Code: P411
My buddy Tim (DTMS) installed his AEM intake a few months ago, and he's been getting a CEL. When resetting the ECU, it stays fine till for a few hours of driving or when the car is restarted (As is to be expected). Autozone pulled the code and said it was P411, which is the Secondary Air Intake.
We've checked all the hoses from the intake, and everything is tight and routed right. What exactly should we be looking for?
Blake
Blake
I had my CEL on when I installed my spoon intake and the error was secondary air flow, took it to dealer change a plug eveything went fine now. it was a plug went bad on one of the hose secondary air flow host.
Incorrect flow in vaccum lines check for misrouting, leakage, breakage or clogging.
If all the lines are correct then it is the air control valve vacuum control solenoid valve...............dam such a long name for a little part........ya might want to check the No. 6 acg (15a) fuse
in the under dash fuse /relay box if it's blown than ya have a short between the the fuse and the guage assembly.
P.s. the the air control valve vacuum control solenoid valve is the piece where all the vacuum line come together the one ya attach directly to the aem cia with a bolt.
good luck.
good luck.
S2k_Jon
May 13, 2004 02:03 PM
