OE O2 Sensor connector
Old Jun 27, 2006 | 09:39 PM
PilotKD's Avatar
Default OE O2 Sensor connector
I'm trying to get my hands on a used sensor harness (the sensor side) and I've found one from a Civic that looks like it'll work. I've read that Honda has pretty much used the same O2 sensors for most of their late model cars, including the Civic and Accord. I've seen a few pics of the S's connector in various forum threads, but can't make out much detail. They look the same, but can anyone verify if this will work:
Civic Sensor
Thanks!
Old Jun 27, 2006 | 11:23 PM
jzz30's Avatar
yes sir that is the same connector.
Old Jun 28, 2006 | 04:25 AM
Slows2k's Avatar
The connnector shells are the same, but each 02 sensor uses different sides of the connector so you don't plug them into the wrong plug in the harness. One 02 uses the male side of the plug, the other 02 uses the female side.
02 sensors also use different heaters between the primary and secondary sensor. So if it does plug in, it may not work properly.
Old Jun 28, 2006 | 03:39 PM
PilotKD's Avatar
Cool. I just need one for the front O2 sensor. I'm going to install a wideband and want a spare harness to hack into for the resistor mod (to keep the ECU happy). This Civic sensor is the front sensor and looks like a female connector. I'm assuming the S2000's is the same? (female vs male).
Old Jun 28, 2006 | 07:05 PM
Slows2k's Avatar
This is a Secondary 02 heater simulator I built, so the Primary 02 will have the opposite connector. (male plug and terminal pins) (
Old Nov 1, 2006 | 08:54 AM
s2k_jay's Avatar
i'm looking to get a 02 sensor for my05..but just wondering i can't just get it from civic..accord..prelude or others?..because i called up honda and they want 250 or something or the oem sensor
s2knOOb02
Jan 17, 2008 08:06 PM
