OEM Air Cleaner/Vacuum Tank
I replaced an aftermarket intake with a used OEM air cleaner/intake. I'm trying to find some replacement parts that are broken or missing but I have a few questions.
- My vacuum solenoid appears to be missing the bracket to mount to the air cleaner box. I found the complete assembly in #2 in the link below, but is there a way to just get the bracket to mount the solenoid?
https://www.hondaautomotiveparts.com...l--vacuum-tank
- The hose that connects the front of the engine and the left side of the intake tube is too long from the aftermarket intake. Would it be a good idea to cut this to length or is there an OEM hose I should buy? I'm having a hard time determining which part number/hose it is from the diagrams.
- I cracked the intake tube where the hose above connects. I believe I found the part in the link below, so my question here is, is this a good site to order all these parts or do you guys recommend a different site for OEM parts?
https://www.hondaautomotiveparts.com...ow-17228pcx000
cottoncandyek
Southern Ontario For Sale
04-15-2014 06:34 PM
