OEM hardtop fitment
My driver side window barely grazes the hardtop when I shut the door. I've adjusted it per service manual as well as got the correct measurements for the rear gap.
I also took out all 3 shims under the front latches with no avail.
Shoot me some tips I'm impatient
1. Make sure you have hardtop latches.
2. If you have hardtop latches, take them off to remove any spacers (you already did this)
3. Make sure you have hardtop strikers.
4. Loosen all the rear bolts
5. Attach front
6. Tighten rear bolts.
7. Attach rear.
Good luck
5. Attach front
7. Attach rear.
Good luck
I had to make some adjustments on mine to fit as well. Loosen all the bolts and tighten them down after you get it straight. It took me a more than once to get it right. Im thinking you dont have the correct strikers in place.
It hits at the top of the window towards the front. I don't see how adding shims would make it further from the window, it would make the latch lower causing more of a pull on the top
I tried adjusting it per J schmidt instructions. Still no dice
I have Hardtop strikers (6 months old) and the Latches are Hardtop latches. I checked myself.
I ended up adjusting the window. Its better but not perfect.
-Mike
I know where the shims go. The top is stationary. Physically take the latch and pull it down away from the top. You now have greater force pulling on the top to keep it latch.
Pauly15
Jan 22, 2014 02:12 PM
