Ohlins Coilovers
Old Feb 14, 2008 | 03:03 AM
dwedge's Avatar
Default Ohlins Coilovers
These are great coilovers.
Only question is how good are the OEM tophats?
I'm having no problem at the moment, so I presume it will be ok, though..
Old Feb 14, 2008 | 03:58 AM
joes sled 2000's Avatar
Just use the oe top mounts. This is how my ohlins came.
jdmfool's Avatar
thats weird that it didnt come with top hats did you contact your seller and ask why he took them off or sold them to you that way?
Old Feb 14, 2008 | 06:22 AM
nearwater4me's Avatar
All coilovers don't come w/ the top hat.
OEM top hats from the stock shocks are re-used.
You're fine.
Those coilovers
Dan
Old Feb 17, 2008 | 03:04 PM
Antonov's Avatar
I have the same coilovers and I'm researching pillowball upper mounts. Looks like you are running swift springs. What are the specs?
free length?
i.d.?
rate?
I'm switching to 60mm springs, and I'm trying to find pillowball upper mounts that have a 60mm seat and Ohlins/OEM shaft diameter.
Any help or knowledge on spring id's and shaft diameter of common coilovers is welcome.
(edit) looks like you have the Japanese version, which I think just uses a different body which allows preload adjustability independent of height. Probably still a MCJ insert.
AZ-S2000
May 2, 2012 04:03 PM
jdm jedi
Oct 1, 2007 11:23 PM
