Oil Bolts
Hello everyone,
Fairly new to the board, I recently purchased a 02 S2000, I have read a lot about these oil bolts and trying to figure out if these blots were updated on production O2's if so is it after a certain production date or vin #.
Also I have heard of people running Iridium plugs. Is there an advantage to these plugs and is so when stock or with modifications.
Thanks !
Thanks !
Waterhound7-
This is the info I could come up with. Look at your engine serial number. If it is after #1025386 then it has the new bolts.
I hope this helps,
Glen
[QUOTE]Originally posted by Prolene
[B]Per UL's dyno: "...2002's show a consistent gain above the 2000-2001 models..."
Per vapors2k:
I hope this helps,
Glen
Per vapors2k:
Thanks !
Thanks !
Originally posted by Surf2k
Where is the engine serial number located?
Thanks again everyone, Now I need to check and see, hopefully I have the new ones, if not how hard is it to change them !
