Oil Capacity??
Old May 9, 2002 | 12:15 PM
js2000's Avatar
Default Oil Capacity??
Hello all,
I just picked up an 01 S2000 with 5K miles on it. I had to order the owners manual and until then wanted to change the oil. Does anyone out there know what the oil cap. is with filter change?
Much appreciated,
Jason
Old May 9, 2002 | 01:34 PM
twohoos's Avatar
Welcome. This is actually not as easy a question as it appears. The owners manual states 5.1 qt, but most users feel it's a misprint and the actual capacity is higher. (Do a search.) I find 5.3 is about right, though some swear their car takes 5.5. To my knowledge there's been no definitive resolution of the issue. (Surprising, I know!)
Just fill to the top of the XX's. Also note that the two sides of the dipstick may disagree -- if so, use the lower reading.
Old May 9, 2002 | 02:20 PM
Tedster's Avatar
I think 5.5 is about right, d@mn close to 6.0 if you use a larger oil filter like the Mobil1 M1-105.
Ted
Old May 9, 2002 | 02:22 PM
jerrypeterson's Avatar
Even more with a supercharger. Stock you should be 5.3-5.6 quarts. But why get technical, you are checking the oil level after you change it right? It will need what it needs.
Old May 9, 2002 | 08:52 PM
joe_s2k's Avatar
Ted
I change my own oil and 5.5qt. does it for my MY2000 every time.
Old May 10, 2002 | 08:57 AM
js2000's Avatar
Thanks everyone! 5.5 seemed to be the magic #. I also have an 02 Corvette ZO6 which takes 7 qts. opposed to the manual saying 6.5. I appreciate the input.
Jason
Old May 12, 2002 | 10:18 PM
161MPHTOPSPDS2K's Avatar
[QUOTE]Originally posted by twohoos
[B]Welcome.
Old May 13, 2002 | 09:18 AM
twohoos's Avatar
Originally posted by 161MPHTOPSPDS2K
I believe that the oil dipstick tube curves at the very bottom of the oil pan.So you should fill it to the xx mark.Which ever side hits the xx first, it should be full.usually the bottom side.I know this because im a tech for honda.R u guys starting the car after you guys fill it with fresh oil?It ranges from 5.0 to 5.5.
What do you mean the xx mark? There are 5 Xs I think.
Old May 14, 2002 | 11:40 PM
the xx marks at the top of the dipstick when you pull it out.When its full it should go to the very top of the xx mark.
bkmagby
Nov 19, 2006 06:31 PM
SWIFT2000
Dec 16, 2005 08:08 AM
F20_C
Sep 3, 2005 06:26 AM
Lurker1222
Dec 19, 2004 07:20 AM
Shipley
May 21, 2002 12:55 AM
