Oil catch can problem
Old Feb 9, 2004 | 01:26 PM
AP1_rock's Avatar
Default Oil catch can problem
I recently installed my Cusco catch can according to the directions in the box. Now, i'm throwin a code after i reset the ecu(disconnected the battery).
any idea how i can find the code i'm throwing? or what it may be?
Old Feb 9, 2004 | 01:36 PM
Slows2k's Avatar
You need to get the Code before any further diagnosis, Your dealer can pull it, Autozone can pull it, just don't expect any troubleshooting there.
As far as your catch can install goes, I only see 1 line hooked to the breather fitting on the valve cover. The front breather is for fresh air inlet with a PCV valve. You will not collect any oil with your catch can plumbed this way. The can needs to be between the PCV valve and the intake manifold to work.
Old Feb 9, 2004 | 01:42 PM
Slows2k's Avatar
Here's a link on how to plumb the catch tank:
http://www.s2kca.com/forums/showthread.php...p?threadid=2257
Old Feb 9, 2004 | 01:47 PM
AP1_rock's Avatar
cool, thanks for the help.
i just followed the directions that came with the catch can
Old Feb 9, 2004 | 01:53 PM
Slows2k's Avatar
For some reason there seems to be a bit of a debate on how to plumb a catch can. Some insist on Y'ing the PCV line and front breather line into the can, which is nothing more than a remote breather. I think the crappy install instuctions from the JDM cans are to blame,
Old Feb 9, 2004 | 02:02 PM
Gernby's Avatar
Former Sponsor
Attaching a catch can to the front of the valve cover is a waste of a catch can. The air flows IN at that point, so no oil will flow OUT at that point. The catch can should be connected between the PCV and intake manifold.
On a side note, I filled my catch can 1/2 way in 20 minutes yesterday at Motor Sport Ranch. I checked and refilled my oil, then didn't see another drop in the catch can for the remainder of the day (~60 minutes).
Gernby's Avatar
Former Sponsor
BTW, even though your catch can isn't installed properly, I don't see any reason why it would be throwing a code.
Old Feb 9, 2004 | 02:11 PM
Slows2k's Avatar
I agree
Old Feb 9, 2004 | 04:36 PM
Tech2Drew's Avatar
Cusco says to hook only the PVC valve to the Catch can and plug off the intake. That is how I'm running it.
Drew
Old Feb 9, 2004 | 04:38 PM
Tech2Drew's Avatar
Edit
