oil ch ch change ?
Originally Posted by hyoseke,Mar 25 2010, 11:25 AM
Not to hijack the thread but, do you know how long the OEM filter will last?
Not sure how to answer, but from reading some older posts from guys like Road Rage and xviper, you could easily keep the filter for maybe 2 OCI's. But as cheap as they are, it shouldn't be an issue to change the filter with every OCI, assuming your OCI's are fairly accurate.
Originally Posted by S2Hey,Mar 25 2010, 01:32 PM
Sweet thanks for the info and direction.. a couple other things though.
where can I get an oil analysis done? Thanks.
Anyone changing their oil early is fooling themselves. go the 7500 on syn or further. Dino oil stick to the 7500 or when your car tells you to change the oil.
Any 'feel' you might have is largely in your head. You might however notice some oils keep your motor quieter than others - thinner vs. thicker. To 'feel' the amount of resistance difference we're talking about would be near humanly impossible. Unless you were going from a 40/50 weight down to a 30 weight.
Originally Posted by Reckon,Mar 25 2010, 01:25 PM
The OEM filter is a very good one and does its job well.
Honda Part# 15400-PCX-004 is made by Filtech, not Fram and is superior to Fram in all regards.
Everything you should know...
https://www.s2ki.com/forums/index.php?showt...&#entry10104759
And the tear down/comparisons of the K&N filters don't exactly speak well for them.
Originally Posted by S2Hey,Mar 25 2010, 12:47 PM
Whats up guys. I have an 06 gpw. s2k with 35200 miles on the car. i think its due for an oilchange so i was wondering
what oil should i use for my mileage? I was told the dealership uses some conventional oil. so What do i use? What is recommended by s2k enthusiasts?
on my odometer it shows my oil life % and it is at 60. is this a good measure of when to change oil?
