Oil Change Comptech SC
Old Sep 27, 2015 | 11:58 AM
ceophlo's Avatar
Default Oil Change Comptech SC
Purchased my AP1 and now I need to do an oil change. The car came with a Comptech Supercharger. So the oil drain plug is really a line for the supercharger. I'm scared to touch it because I don't have a open end torque wrench and I don't know if when I tighten it back I would be stripping it. What should I do? Risk it?
Old Sep 27, 2015 | 12:08 PM
Habitforming's Avatar
Buy a set of crow foot wrenches
Old Sep 27, 2015 | 12:42 PM
ceophlo's Avatar
Please excuse my ignorance. How do I use that with the torque wrench?
Old Sep 27, 2015 | 02:33 PM
jcconnox's Avatar
Crowfoots are awesome! They'll make any square drive socket wrench an open ended wrench.
Edit: Crowfeet?
Old Sep 27, 2015 | 03:04 PM
Just snap it on to the 3/8 drive lug
http://i149.photobucket.com/albums/s...rowsFoot_3.jpg
Old Sep 27, 2015 | 03:56 PM
ceophlo's Avatar
Originally Posted by ceophlo' timestamp='1443386543' post='23759155
[quote name='Habitforming' timestamp='1443384519' post='23759139']
[/quote]
awesome. i love this forum. i'm going from noob to car guy in no time.
Old Sep 27, 2015 | 04:53 PM
Originally Posted by Habitforming' timestamp='1443395085' post='23759233
[quote name='ceophlo' timestamp='1443386543' post='23759155']
[/quote]
[/quote]
great! That's what we're here for. Remember, the only stupid question is the one you don't ask.
Old Sep 28, 2015 | 01:40 PM
steven975's Avatar
What I do is that I use another open-ended wrench to prevent any torque from being applied to the fitting attached to the pan.
The hose fitting to that fitting I just hand-tighten with another open-end wrench...it's not as torque sensitive as what is going into the pan (as that is soft aluminum).
If you want to be precise and use the crowfoot, it does change the overall leverage you need to apply. For example, to hit 10 lb-ft, you may need to apply 9.X lb-ft (indicated) with the crowfoot attached to apply an actual 10 lb-ft, as your fulcrum is longer.
Old Sep 28, 2015 | 09:02 PM
silverstone_f22's Avatar
If you put the crows foot at a 90 degree angle to the wrench no torque calculations are necessary.
Old Sep 29, 2015 | 09:38 AM
slalom44's Avatar
Top Answer: 1
I have a similar drain plug setup (My drain plug port has a line that feeds my prelube pump). Here's my suggestion:
Set your torque wrench to 29 lb-ft and practice on another bolt. Any other bolt. A lug nut will do. See how much force it takes to get 29 lb-ft. Now that you have a feel for the correct force, use the same amount of force with a wrench of the same length as the torque wrench.
I have done it this way for over 12 years. I've never had a problem.
