oil change needs...
Originally Posted by hpark,May 25 2005, 07:27 PM
you should use the PCX Honda OEM oil filter....get from dealer or order online at hardtopguy or whereever.
2 jack stands minimum, but i'd get 4 jack stands and just lift the entire car......less drama cause you don't have to lower the car and raise again to drain the oil.....
Originally Posted by ayS,May 25 2005, 07:56 PM
thanks wisconsin on the heads up! , i just went and picked up a oil filter and drainbolt washer. i i am currently coming up on 3k. i just picked up some mobil 10w30 as well. hopefully, it's okay oil?
oh and I'm going to add this to our oil journals. check this out from honda:
https://www.s2ki.com/forums/index.php?act=m...mage&img=216856
click on the picture to enlarge it.
Glad to see you didn't take the advice about picking up the air filter. You have a relatively new car and with only 3K on it, the air filter should be fine. Most people check the filter annually or every 15K miles or so and then decide if a new one is needed. The OEM air filter is not so cheap that you can just replace it at every oil change. I'm glad you have the common sense to weed out the garbage advice when you see it.
Originally Posted by Wisconsin S2k,May 26 2005, 02:50 AM
how many miles are on your S2000?
Originally Posted by ayS,May 26 2005, 07:31 AM
the autoparts store told me i didn't need a torque wrench? is this true?
plus a torque wrench is just handy to have for other tasks, like retightening the lugs on your wheels. good luck!
