Oil Change question
I got a quick question concerning oil changes. Today i changed my oil and when i installed the filter i forgot to put the washer over the threading on the engine. I haven't started it up yet but and I am wondering if the washer is absolutely necessary??? Do I need to do the whole damn thing over again?? Thanks guys.
-Ian-
-Ian-
Are you referring to the crush washer that goes on the oil drain bolt or are you referring to the rubber gasket on the Oil Filter? Either way....both are necessary to prevent leaks and form a tight seal.
As Ken said, BOTH are necessary.
when i went to honda to get the filter, i got the filter and then they gave me a metal washer with it. does the washer go on the drain plug bolt or on oil filter?? Sorry, im kind of a noob with honda's and i didnt see which it came off of. Thanks again
-Ian-
-Ian-
-Ian-
-Ian-
-Ian-
-Ian-
It doesn't go on the filter, even though they give it to you with the filter. It's sort of like an "oil change kit".
good thing you "forgot" to put the washer on the threaded oil filter pickup....... no washer belongs there. it isnt just a honda thing, when installing the oil filter next time, just insure that you dab the new oil filter with some fresh oil around the rubber piece, screw onto the threads and firmly hand tighten.
next time remember to install the washer they give you onto the drain plug.
Originally Posted by mikegarrison,Jun 20 2006, 11:20 PM
Bad advice, actually. Honda has a torque spec for the filter, or they also recommend the equivalent "7/8 of a full turn after the first contact". Either way it is quite a bit more than what most people consider "hand tightened". S2000 filters that were just hand tightened have been known to come loose.
