Oil Change By Sucking it thru the dipstick
This is what I have, Mityvac Fluid Evacuator Plus:
http://www.tooltopia.com/index.asp?PageAct...ROD&ProdID=8587
It works flawless on Mercedes Benz cars and trucks, because they are designed to use vacumm to suck out old oil from the dipstick tube.
I used it on my S twice, it worked okay the first time after several tries, but I could not get all the old oil out on second trial.
Then again, it seems like the German cars were designed with this in mind. Now, for the S, I do it the old fashioned way. Just makes me feel better. But I think for people who live in the city, with no garage space, the Mityvac is a Godsend.
I'm surprised noone has mentioned the Fumoto Valve yet. I do it the old-fashioned way and jack up the car (even with my aftermarket intake), but numerous people swear by the Fumoto. Kick a drain pan under the car and flip the valve to "open" and drain to your hearts content.
Just another option.
-Hockey
-Hockey
Originally Posted by Zeemz,Aug 15 2006, 01:51 PM
Anyone had any good experience with one?
I've heard of alot more loose drain plugs being improperly tightened by dealers and/or grease monkeys which lead to dumping oil.
I'd put it on if someone gave it to me.
Like I said I get down and dirty the old-school way and don't want to spend the $40 on the Fumoto.-Hockey
Fram also makes one...
It replaces the stock bolt, and then there is a second part that pushes the locking mechanism in and drains the oil. Also comes with a tube so that you can put the oil where you want it.
There is a cap for the bolt when you are done changing the oil so it will stay debris free.
I wouldnt trust that valve with the handle. I just do it the regular way anyways. Only way i would use one of those ways is if the drain plug threads got stripped.
Originally Posted by Hockey,Aug 15 2006, 04:02 PM
I think in the 4+ years I've been involved with this site, I've heard of maybe 1 or 2 times when the valve has opened on its own.
