Oil drain plug Question
Well Im going to try it out this weekend since I have the new bolt. I think I might have over tightened the bolt a bit. I might try to heat it up to remove it as a last measure.
But it looks pretty stripped. The 17mm socket I was using doesnt even grap it anymore.
So I might need to use some pressure pliers to take it out.
OK, it's the bolt head that's rounded off.
That's surprising considering that the threads are naturally lubricated with oil and the torque specifications are pretty low for a bolt that size.
Before you use heat, try a correctly sized 6-sided socket or Vice-Grip type pliers.
Originally Posted by Slows2k,May 13 2008, 04:38 PM
You guys are confusing bolt head size with thread size.
OEM honda drain plugs all have 17mm heads, and 14x1.5mm threads. The length of the threads depends if it's going into a steel or aluminum pan. Steel pan drain plugs are shorter.
So both 17mm and 14mm are both "correct"
-Hockey
BTW, if it is on there that tight then it was over-torqued by the person that did the last service. The correct torque setting is surprising light when you feel it.
Further, if a bolt is M8x1.25 it will have a 12mm hex-head if it is JIS (Asian) but a 13mm hex hid if it is DIN (the rest of the world.) In either case, it's an 8mm bolt not a 12mm or 13 mm.
RA31125
Mar 22, 2004 03:31 PM
