Oil indicator light
Fellas..
How long does your oil indicator light stay on after start? Mine tends to hang for 3 to 4 seconds. Oil level is always fine, and my car tends do do this. But sometimes i almost reach for the key to shut her down. I have an AP1 with what i estimate is about 80K on the motor ( It was a factory replacement around 50K miles, clock shows 131K )
Just wondering, ive never really see anyone here talk about the oil pump unless they have a blown motor to deal with.
I use 10w30 Castrol Edge or Amsoil ( when i can float the cash ). Always use OEM filter.
Fellas..
That doesn't sound normal at all. That light should only be on while the car is cranking. As soon as ur car starts the light should disappear . The only time that light stays on even for a second or 2 could be after an oil change.
As long as it doesn't come on while running, you should be fine however the only way to know for sure is with an oil pressure gauge.
Do you let your car sit for long periods of time in between starts?
Either way the idiot light is useless, get an oil pressure gauge.
To Op. Go on youtube and type in start up s2000. As u can see on normal running s2000's the light turns off immediately when the car starts
Like I said, only way to know for sure is with an oil pressure gauge.
Edit: 3-4 seconds does seem like a long time, but his oil pressure sensor could just be tired, they do go bad.
Thanks for the replies guys. The car has been like for years, its not something that just started happening. I do let it sit for days as i use a beater car monday through thursday. Ill have to research this more i guess..i dont think it does it if the car sits an hour but all day while im at work it will.
Ill post avid of this myself and you guys can give me your thoughts...
Just fyi, mine does this sometimes however I do have a oil pressure gauge hooked up and my pressure is fine. Like I said in my previous post, the switches can go bad, heck mine is 12 years old.
