oil lamp..?
Old Nov 28, 2008 | 03:39 PM
xin2kill's Avatar
Default oil lamp..?
hey i was wondering why is the oil lamp blinkin when i said blinkin i meant like really fast i dont no wats wrong with it some help would be good thx!!
Old Nov 28, 2008 | 03:51 PM
negcamber's Avatar
Check your oil level.
Old Nov 28, 2008 | 03:58 PM
xin2kill's Avatar
yeah i loooked at it quite a few time alreadi its above the second X
Old Nov 29, 2008 | 07:28 AM
s98d7fs's Avatar
Please sell your car to someone who can read a dipstick.
Old Nov 29, 2008 | 04:32 PM
ahrmike's Avatar
well, assuming he is checking the dipstick correct, at warm, with the car being level,
it could be the oil sensor that the car has...thats broken!
i had that before..camaro oil pressure sensor broke (snapped in half, after clutch install...) and it read 0psi for a while
Old Nov 29, 2008 | 10:35 PM
xin2kill's Avatar
man u no damn well wat i meant
Old Nov 29, 2008 | 11:24 PM
armthehomeless's Avatar
I had an 1920's ford with oil lamps on it.
Old Nov 30, 2008 | 12:06 PM
s98d7fs's Avatar
Please also use correct spelling and grammar. People are much more likely to help you if they don't have to translate misspelled slang.
I'll borrow a picture from S2kman (which I found by searching the forums; a very very useful feature):
See how the 2nd X is not at the H mark. The H mark is where your oil level should be when the oil is hot. If you're reading your oil level from a warm engine and you're seeing only two Xs, then you're probably low on oil. Again, this is assuming you know how to correctly warm up the car, drive it to a level surface, turn it off, pop the hood, pull the dipstick out and wipe it off, wait 5 minutes, insert the dipstick back into the engine (all the way), and then pull it back out and look at it.
Old Nov 30, 2008 | 01:40 PM
Slows2k's Avatar
Complete sentences and a better attitude would help you here as well.
Old Nov 30, 2008 | 01:48 PM
luder_5555's Avatar
i really think that he just enjoys making threads that have no meaning, just look at his post history, i mean no one that can drive stick is as ignorant about cars as he seems to be.
S2K-OED
Nov 10, 2016 09:52 AM
jeremicium
Jul 31, 2013 08:48 PM
S2K-Phil
Car Talk - Non S2000
Dec 6, 2009 06:02 AM
P'sS2k
Apr 12, 2008 10:32 PM
tenblade2001
Oct 18, 2002 03:55 PM
