Oil leak
Old Oct 6, 2017 | 04:34 PM
kschoenefeld's Avatar
Question Oil leak
My 2005 AP2 recently started leaking oil, and I can't find the source. It drips close under the oil filter. From the top, it gets on the cross-frame. I can't feel or see oil below the filter where it would run if it were the filter or cooler plate. Under the car, it, of course, gets on things rear of there. I am taking it to a repair shop to help pinpoint the leak, but if anyone has any ideas, it might help in locating. Also, dry under the crankshaft balance. It seems that if it was the oil pan, it would not get on the cross member because that is in front of the pan. Baffled. Thanks!
Old Oct 6, 2017 | 04:46 PM
Mijae007's Avatar
Tct? Vtec solenoid? Some common areas of leak on that side of the engine.
Old Oct 6, 2017 | 09:55 PM
Car Analogy's Avatar
This. Look higher than where you've been looking. Leaks flow downhill.
Old Oct 7, 2017 | 07:18 PM
Thanks for the advice. I do not feel any oil under the tensioner or solenoid....
Old Oct 9, 2017 | 08:45 AM
Timing chain cover is cracked. Mea culpa. I damaged it when changing the idler pulley. Expensive repair.
Old Oct 9, 2017 | 02:16 PM
Soviet's Avatar
Originally Posted by kschoenefeld
Timing chain cover. Expensive repair.
So it's leaking from the TCT and not the valve cover gasket?
beefystud
Apr 21, 2017 02:19 PM
kylemonster85
Jul 18, 2007 09:02 AM
Tuanster
Nov 20, 2006 07:56 AM
kstokell
Aug 31, 2004 04:16 AM
minboost
Sep 12, 2002 03:28 AM
