oil light
Old Apr 2, 2009 | 02:35 PM
1stuey1's Avatar
Default oil light
just wondering may not be anything, but when i switch in the ignition all the lights show on the dash, i then start the car they all go out the oil light goes out flicks on for a mill a second and off! not even between a second now! i changed the oil recently to 10w40(honda dealer said this) its prob always done this but i saw recently! never comes on driving or anything! (this happens on cold starts) ? prob noting but thought id check
Old Apr 2, 2009 | 03:13 PM
Nate4635's Avatar
Have you checked your oil?
That light would indicate low oil pressure
Old Apr 2, 2009 | 04:00 PM
IcebergS2000's Avatar
Where are you located that the dealer suggested using 10w-40? What is you weather like? I have actually been thinking of trying 10w-40 in the S.
Old Apr 2, 2009 | 09:29 PM
fastD's Avatar
10w-30w is your friend...
Old Apr 2, 2009 | 10:18 PM
SquirtleS2K's Avatar
Heh... whats the oil cap say?
Old Apr 2, 2009 | 10:56 PM
1stuey1's Avatar
oil is perfect topped up! weather is cold and crap over here as always haha
Old Apr 3, 2009 | 04:43 AM
1stuey1's Avatar
and it a spurious filter in it too!
Old Apr 3, 2009 | 05:31 AM
Nickamsweet's Avatar
I have had this problem since i went from my old oil (which apparently isn't made anymore) to the 10W-40 castrol magnatec. Now every time i turn on the engine the light will come on for 1/4 to 1/2 a second then turn off straight away... I know my oil level is correct its just that it can't be that healthy EVERY time i turn the engine on to not have instant oil pressure!
Old Apr 3, 2009 | 05:33 AM
JoeyBalls's Avatar
its normal
Old Apr 3, 2009 | 08:15 AM
slipstream444's Avatar
10W40 is really too thick for any relatively stock AP1 or AP2 for temps below 45C-50C. So unless you live in the Middle East or in Death Valley - there really is no reason to run a 40 weight oil.
5W30 is fine for colder climates (frequently below freezing), but 10W30 is what the engine is designed to run in almost all temperatures.
The flickering oil press light is because your car is not able to circulate the 10W40 immediately - because it's too thick, especially at colder temps. That means your car is staved of oil flow at one of the most critical times - immediately following start-up.
Change to a 5W30 if the temps are very cold, or a 10W30 and this should stop.
Before anyone chimes in on this one... regardless of what some may think - a 10W30 and 10W40 are not the same thickness when cold. A 10W30 is thinner.
Go to any oil manufacturers website and compare the specs for their 10W30 and 10W40 and you'll see there is a difference.
