oil pressure sensor
Old Jan 29, 2006 | 05:18 PM
bfaler#3's Avatar
Default oil pressure sensor
Had a real problem happen with my '00 S2K. The car shut off while I was driving. I coasted to the side of the road, and found that there was new oil sprayed all over the engine compartment. The dipstick showed the engine was bone dry. It turns out the oil filter gasket had cracked and all the oil had spilled out. I never had any warning light come on before this. I replaced the filter/oil, but the car still won't start, though it will turn over. Is there a switch or something that prevents the car from running/starting on low pressure that needs to be reset before the car will start?
Old Jan 29, 2006 | 05:53 PM
Slows2k's Avatar
No such switch exists exists. Sounds like you may have a much larger problem. Does the green Key light flash while you are trying to start the car?
Old Jan 29, 2006 | 06:11 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Curious...what type of filter was it?
Was it the blue Honda 15400-PCX-004 or something different?
Sounds like it was not properly tightened.
It is likely you cooked the engine, hopefully I am wrong.
Old Jan 30, 2006 | 04:36 AM
bfaler#3's Avatar
It was a FRAM filter. I don't believe the key light flashes. It's up at the shop now. I have my fingers crossed but the prognosis may be grim. I'm not sure how this would fit into my extended warranty.
Old Jan 30, 2006 | 05:46 AM
Squeezer's Avatar
FRAM
Old Jan 30, 2006 | 05:49 AM
vtec9's Avatar
If you have an extended warranty through Honda, and the dealer did the last oil change (although I doubt this is the case since I don't think they would stick on a fram), then you should be able to get some help. If you or a 3rd party stuck on that filter, you're out of luck. Did the car make any noises before turning off? Bone dry engine = not good.
Old Jan 30, 2006 | 06:56 AM
3ngin33r1's Avatar
This doesn't sound good.
Owen_1987
Sep 26, 2018 10:57 AM
only9k
Nov 26, 2012 05:20 AM
03suzuka...s2000
26
Apr 9, 2012 08:25 PM
Ek_Jak
May 11, 2010 04:38 AM
Steven2k
Nov 15, 2006 04:26 AM
