Oil Smell of gas
Hi all
i have recently changed all the fluids, plugs, air filter, cos my engine seems to be down on power and very low mpg
i only gets around 220miles per tank with steady driving no vtec. the low end power is alot weaker than other AP1 i have driven.
the idle drops when i am sitting at the lights for more than 10sec with the aircon on. i have cleaned all sensors and did MAP whack
so today i decided to check my oil and it smells of gas !!!
help needed =(
car is stock except mugen filter and test pipe.
help needed =(
done compression test, all over 16bar.
just informed by a friend, my car have a puff of black smoke when changing gears at around 8-9k rpm
what plugs are you using? some of the "fancy plugs" don't spark as well as ngk's or denso's (factory style), thus not burning all the fuel in the combustion chamber and your cylinder walls can become saturated
s2kdriver80
Aug 15, 2014 01:12 PM
