Oil in spark plugs
Old Aug 30, 2010 | 09:24 AM
kylemonster85's Avatar
Default Oil in spark plugs
Hey guys i went to go change my spark plugs today and i pulled out the plugs and had oil on them is this normal if not what could be causing this. I just had my valve cover swapped out could the gasket be the problem or something from installing it wrong???
Old Aug 30, 2010 | 09:49 AM
SgtB's Avatar
If it's on the top of the plug then the valve cover seals are bad. If it's on the electrode side, you may have badly worn rings.
Old Aug 30, 2010 | 11:00 AM
come to find the spark plug covers werent in the valve cover. not before i put the new spark plugs in should i drain out the oil if so how do i get it out
Old Aug 30, 2010 | 11:07 AM
ChefJ's Avatar
Old Aug 30, 2010 | 12:07 PM
zeroptzero's Avatar
if you didn't have spark plug tube gaskets I think the tubes would have been flooded with oil. You likely just had a leak in them, I like to change them out any time the valvecover is removed and I don't trust re-using them. To dry out the oil try stuffing rags into the tubes , use needle nose pliers to pull out the rags, keep doing this until the tubes are dry.
Moddiction
Oct 31, 2022 08:31 AM
joshf47
Jun 18, 2014 11:50 PM
nicenotrice
Jul 14, 2011 04:03 AM
s2k_bmich510
Jan 30, 2008 05:11 PM
Tom Jr
May 13, 2007 01:40 PM
