Open Header/Open Cat
I recall someone saying that there were issues from running an open header/open cat?
I want to know, if it is bad to run your car like this, what happens and why does it happen.
TIA
TIA
*I didn't see your edit
I understand the smells,codes,legal issue
So there are no unsafe issues? I remember reading somewhere that it was unsafe or it would hurt performance.. guess I'm wrong.
Just tried to clear a thought.
Originally Posted by JFUSION,Aug 28 2010, 08:46 PM
you will lose performance with a loss in torque, you need approximately 3 feet of exhaust pipe from the end of a header to maintain torque in the power band.
EDIT Actually on an S2k this might be different. All of the headers I've saw have a very short collector so it'll bolt to the OEM cat. If you do decide to run open header, you might think about bolting different length pipes to the header, to get the optimum collector length.
Originally Posted by realblag,Aug 28 2010, 11:31 PM
A header and short piece of exhaust (proper length and diameter on both) helps scavenge the exhaust from the cylinders therefor more air goes in on the intake stroke.
