Oil Stabilizer
Consider an Accusump by Canton Industries.
And for the love of the gods of horsepower, put in a clutch interlock bypass. Its easy and will potentially save your engine from potential catastrophic failure after many, many dry start cycles.
personally, after the car is stored over winter, I remove the fuel pump fuse, and turn the engine over WITHOUT pressing the clutch in- until the oil light goes out.
darcy
darcy
Darn decimal point!
I suspected something like a typo.
Follow Bill's instructions to the letter. 10 minute job using the provided bolts (NOT the OEM). Press it in, don't draw it in with the bolts. Only "scary" part it pulling the pin out the little hole in the front of the block -- get a good grip on it.
-- Chuck
I suspected something like a typo.Follow Bill's instructions to the letter. 10 minute job using the provided bolts (NOT the OEM). Press it in, don't draw it in with the bolts. Only "scary" part it pulling the pin out the little hole in the front of the block -- get a good grip on it.
-- Chuck
