Out of time?
Old Jul 25, 2016 | 05:51 PM
S_DosMil's Avatar
Default Out of time?
Seems like I can not get the car back in time. The exhaust cam will not line up perfectly even. Any help is appreciated.
Old Jul 25, 2016 | 06:18 PM
Slowcrash_101's Avatar
Your cam wheel isn't lined up properly, get the crank and cam wheel marks lined up first, then worry about getting the camshafts line up.
Old Jul 25, 2016 | 08:11 PM
S_DosMil's Avatar
Thanks what also didn't help was the valves need to be adjusted. Problem solved
Old Jul 26, 2016 | 05:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
In the above pic, the exhaust camshaft is off one tooth counterclockwise.
Old Jul 26, 2016 | 05:51 AM
The marks on the cam wheel aren't lined up with the head either.
Old Jul 26, 2016 | 07:50 AM
S_DosMil's Avatar
So I have read if it's even one tooth off the car will not start? So my car is running does that mean I'm in the clear as far as time? After making the adjustment slow pointed out it fired right up.
Old Jul 26, 2016 | 10:11 AM
Billman250's Avatar
Top Answer: 1
That is not true.
Your exhaust cam is one tooth off, guaranteed.
If you turn the crank slightly clockwise so the camwheel marks are aligned with the head, it will move both cams counterclockwise, making it even easier to see.
Old Jul 26, 2016 | 10:17 AM
S_DosMil's Avatar
That is not true.
Thank you I will adjust later and repost with a picture to make sure I'm good.
Old Jul 26, 2016 | 10:37 AM
windhund116's Avatar
That is not true.
Billman, how does the cam get off by one tooth? Is it due to a prior fix, not done correctly?
Thanks!
Old Jul 26, 2016 | 11:11 AM
Billman250's Avatar
Top Answer: 1
It can only happen during removal and installing of the camshafts.
