Out of time?
Old Apr 27, 2017 | 03:11 PM
  #21
S_DosMil's Avatar
So I'm having another issue and not sure if this is related. The car keeps popping acg fuses. New battery, alternator tested good according to multimeter and autozone tester. Sync issue is still occurring even after replacing cam sensor with know good sensor. I'm stumped? Has to be a ground issue?
Old Apr 27, 2017 | 07:55 PM
  #22
S_DosMil's Avatar
Another question, I found the ecu pinout and I'm unsure how to test the cam sensor. Everything has a specified voltage range. The cam sensor just says pulse. Within what range? Or is it an off or on type deal? So if it's not pulsing that's my issue? Not very specific. Any help is appreciated.
Old Apr 28, 2017 | 03:02 AM
  #23
Chuck S's Avatar
A pulse is like a blinking light. I imagine this has to be tested with the engine running as the cam sensor only shows On when the cam is in a specific place.
Running a non-standard ECU makes this difficult and yours seems to be in beta-testing.
-- Chuck
Old Apr 28, 2017 | 03:20 AM
  #24
flanders's Avatar
You need to hook up an oscilloscope to check the cam signal.
Check this thread and maybe ask for more details https://www.s2ki.com/forums/s2000-un...-start-1172187
Old May 4, 2017 | 01:55 PM
  #25
S_DosMil's Avatar
Can anyone do me a favor and confirm if you disconnect the cam sensor A while the car is running it will die? Still sorting out this issue. Thank you
Old May 4, 2017 | 02:12 PM
  #26
jyeung528's Avatar
i believe you would just get a CEL.
Old May 4, 2017 | 04:45 PM
  #27
Slowcrash_101's Avatar
Mine starts without one connected, just tosses up a CEL.
Old May 4, 2017 | 07:28 PM
  #28
S_DosMil's Avatar
Okay guys thank you very much. With mine disconnected on the standalone the car will not start. We have by passed the cam sensor for now. Could possibly be an issue with ecu.
Old May 5, 2017 | 12:05 PM
  #29
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If a cam sensor is disconnected while the engine is running, it will throw a code but it will continue to run.
doodabooba08
Jun 22, 2013 09:33 AM
iblackness
Apr 11, 2013 02:40 AM
nitewing117
Nov 19, 2007 09:04 PM
ade73
Jul 19, 2004 01:41 AM
BellevueS2k
Aug 9, 2002 07:39 PM
