Output shaft removal?
Can the extension housing and output shaft be removed without trans tear down? i have bearing noise in the tail section of trans and need to replace bearings in this location hasd anyone done this?
2.3aero Posted on Jul 27 2009, 06:51 PM
Tear down as in: #1 - remove trans from the car or as in #2 - taking it apart?
#1 - I donno, by the looks of it you need to drop & tilt the engine & gearbox a lot to reach the upper housing bolts and the shift rod.
#2 - as far as I know: yes.
The output shaft is not attached to anything inside the gearbox.
If those bearings are bad you may want to inspect (& replace) more of them.
And.. the magnet and trans pump inlet screen filter are inside the trans.
alright thanks i have only spent a total of about 30 min under the car so i did not get a good look at the top bolt access. I hate inside of transmissions lol its what im trying to avoid most. i would like to get some info form aus2000 who has just done this repair to see what he suggests. thanks though for the picture and info
musicforthedeaf
Apr 17, 2015 04:37 PM
