OutputShaft and Prop Shaft
I'm going to be installing a differential sent from ricks. I need to know what to torque the bolts to, both the prop shaft and output shafts.
Thanks
Thanks
Originally Posted by Gink5,Mar 3 2006, 04:01 PM
Thanks
Also why not just tighten the bolts as much as possible?
It is ok to re-use the bolts, as long as you can properly torque them to:
24 ft-lbs for an AP1
36 ft-lbs for an AP2
Overtightening is over-stretching, leaving the bolt on the verge of snapping. Usually while your on the gas
Originally Posted by Sideways,Mar 3 2006, 07:57 PM
The prop shaft bolts are famous for getting tighter over time and stripping when trying to remove. Don't over torque the bolts.
Well im going to wait until monday because the mechanic that is diagnosing my old diff has the bolts.....
Anyway So far i have everything ready for when i do get them. The ball joint came apart easy with some wd40 and a hammer. I had a fork but didnt want to ruin the rubber boot.
Is there a torque spec on the nut holding the lower ball joint (the one with the cotter pin)?
