Outside Rear-view mirror shaking
So I noticed one issue with the S recently. It appears that the drivers side outside door mirror glass moves and shakes around with our bumpy roads here in Wisconsin. I was wondering if anyone else has encountered this problem and been able to solve it. Thanks in advance!
i have the same issue as both of you guys... and my innovative engine/trans/diff mounts dont help cause my mirrors vib at idle too, lol.... makes me feel like im drivin a beastly v8, bahahahahaha. also never tried to fix but it dont really bother me
Leave Wisconsin.
You may want to check the "putty" condition behind the mirror. If you pull on the bottom edge of the side mirrors, slowly with even pressure (may take a minute or two depending on age) the mirror will pull free. You will then see how the locking tabs are designed and with that, the (usually) white non hardening putty that is used to keep the mirror in place in the tabs and serve as a vibration dampener. Add some more (too much and it will be difficult to push mirror back into bracket) around best when putty is warm or just bunch up what you have and reinstall.
If you are at it, buy a new Honda mirror for right hand drive cars. It convex and does not have the stupid warning on it about objects are closer.
http://www.ebay.com/itm/Honda-S2000-...0d8ba9&vxp=mtr
I bought one (tried the non Honda one and returned it; optics were crap) and can't imagine life without it now. Love it.
Leave Wisconsin.
That would be really nice. I will take an eye out for those.
Originally Posted by DaGou' timestamp='1396282519' post='23089491
I forget who sells them but you can by a pair of the convex mirrors with a blue tint. Forget what I paid but it was under a $100. It was a vendor here, maybe Modidiction...
Thanks in advance.
Originally Posted by Kenshyn' timestamp='1396328933' post='23090856
[quote name='DaGou' timestamp='1396282519' post='23089491']
Thanks in advance.
[/quote]
You pop the mirrors out carefully by prying from the bottom. Heat (some using hot water while others use a blow dryer). It's a very easy remove and replace. I did mine in under an hour (Moddiction). Do some searches, there are several instructional ones ( best is from a Spoon install). search here for "blue mirrors".
Utah
Originally Posted by Phantom12' timestamp='1396880052' post='23100844
[quote name='Kenshyn' timestamp='1396328933' post='23090856']
Thanks in advance.
[/quote]
Utah
[/quote]
Yeah I found a couple of good writeups out there. I was just curious if the Moddiction mirror needed to be installed into the OE mirror housings, which they do. Thanks for all the help.
