Over rev
Old Oct 22, 2004 | 12:04 AM
Tha_don_7's Avatar
Default Over rev
We'll guys i think i might need some help here. A few weeks ago I was racing my friend's Acura type S. I was redlined on 3rd gear then I accidently shifted to 2nd gear. I immediately put the car on netural and stepped on the brake and then drove it to a parking lot. I listened to my engine and it sounded fine.
While I was going home a celica pulled up beside em and reved his engine we both went. After that I pulled aside and accidently reved my engine on first or on neutral gear to 9000rpm it bounced and then my engine just died off.
I tried to start it up but it didn't start back up. When I look at my dash board all i see is the engine light, Ebrakelight & oil light. My window, top, and head light still work but the car won't start. I took it to honda and they told me my engine is seized. They took off the oil pan and couldn't tell what was wrong unless they take the head off the car.
Honda said these are the stuff that probably will be needed to be replaced.
Head Gasket 78.55
Intake Manifold Gasket $19.57
Six Intake Valves $232.88
Six Exhaust Valves $259.20
All valves seals $90.56
Six Intake Valve guides $86.46
Six Exhaust Valves guides $86.46
Total $853.68 for parts
Labour $935
$350 for something I don't know
Total $2138 plus taxes
Total with taxes $2458.00
These prices are in canadian funds I believe it's roughly $2000 US
This is a rough estimate they gave me. They don't know the price for sure until they take the head apart to see what is really damaged.
I'm shitting my pants right now cause i don't know what is wrong with my car and if I need a head rebuild should I just take my car to a local performance shop instead of honda? Also should i build the internal up while my head's apart or should i just get it fixed? Becuase I was going to add a turbo into my s2000 next spring.
I really hope that someone on this board can tell me what's wrong with my car thanks.
Nate
Old Oct 22, 2004 | 02:36 AM
CoralDoc's Avatar
If you over-revved the engine and made valve to piston contact a head rebuild is the best possible solution. Hopefully the head is rebuildable and there isn't any damage to the pistons.
You will have to wait until the head is off for a complete diagnosis, and since the engine isn't running, it's not worth doing any other diagnostics (like inspecting with a boroscope). Let us know what the dealer says - but US$ 2k sounds quite high.
Old Oct 22, 2004 | 07:23 AM
Tha_don_7's Avatar
right now the car is sitting at my buddy's place he said he'll charge me 400 to take the head off is that a bit high? I was going to take it to honda for them to do the repair but im worried one the head's off they'll screw me over big time with the money. I'm not to sure where to take it now.
Old Oct 22, 2004 | 11:15 AM
CrAzYNeSs's Avatar
Member
i think ur friend is charging u a bit high for just taking the head off... im sorry to hear about your car.. i feel ya
Old Oct 22, 2004 | 02:13 PM
AZS2000's Avatar
400 just to take the head off??
Old Oct 22, 2004 | 02:30 PM
LivingLegend's Avatar
I got charged from Honda $760 to take the head off and do the compression and leak down test.
Old Oct 22, 2004 | 04:50 PM
jyeung528's Avatar
let us know what happens.
Old Oct 22, 2004 | 04:58 PM
jankemi's Avatar
If it is actually seized, you'll need way more that $2500 to fix it. Does it crank when you push the start button?
Old Oct 22, 2004 | 05:15 PM
alexf20c's Avatar
Old Oct 22, 2004 | 06:27 PM
Tha_don_7's Avatar
Nope the engine doesn't crank at all.
