Over rev
Old Jul 7, 2007 | 09:49 AM
arprice's Avatar
Default Over rev
First of i have a 03' with 81,XXX
i was at 9k in 3rd went to shift to 4th and hit 2nd by mistake and over reved.
now it idle normal at 900 / 1000 but its a little sputtery and saound like its running on mild cams at idle
runs fine and all still pulls good but the idle worrys me?
Old Jul 7, 2007 | 09:59 AM
CKit's Avatar
I'd say your engine is about to take a dump.
DON'T redline it and take it directly to the dealer to have the valves look at before you blow a connecting rod through the block.
Cracked retainer or bent valve FTL!
Old Jul 7, 2007 | 10:13 AM
SIIK2NR's Avatar
Your engine is screwed.. take it in before you do MORE damage.
Old Jul 7, 2007 | 10:53 AM
iam7head's Avatar
oh man, why are you still running the car when you know you break something?
common sense told us you should have the car checked out.
Old Jul 7, 2007 | 10:55 AM
arprice's Avatar
i took the valve cover off. spring and retaners are good and bad idel comes and goes
Old Jul 7, 2007 | 11:27 AM
Stratocaster's Avatar
You can't tell from the top if the valves are bent. Get it into a shop and stop posting until you do.
Old Jul 7, 2007 | 12:07 PM
vspc2nr's Avatar
I saw a issue of a Honda magazine that did the same thing you did. The tip on one of the valves(the part that you put the retainers on) broke off.
Old Jul 7, 2007 | 12:54 PM
Tyraid2K's Avatar
omfg get that car to a reputable shop or dealer NOW, nothing about that engine is right anymore
Old Jul 7, 2007 | 01:41 PM
CKit's Avatar
Billman has pictures of cracked retainers that you can't tell until you look reeeeeally closely... those are the things that continue working... until they don't.
Old Jul 7, 2007 | 09:05 PM
ncboy7o4's Avatar
Unhappy
dude you messed up your car...probably some cracked retainers. i had the same symptoms on my car... funny idle but still pulled strong, cracked the head open and found all my intake retainers cracked and on top of that one retainer shot me in the eye because the valve stem broke. i almost dropped valve but luckly i didnt.
