Over Rev
Old Sep 24, 2011 | 04:06 PM
LS What?!'s Avatar
Default Over Rev
Somebody give me the definition please. I think this term is used to loosely. I know a mechanical over rev is bad. I've experienced this.
However, people say they over revved a couple times but don't think it hurt the motor. I don't consider hitting the limiter an "over rev". That's what it's there for. I understand it cuts fuel and it's hard on the motor but an occasional touch to the limiter should do zero damage. Correct?
Or am I to understand that even so much as bumping the electronic limiter can cause vlavetrain damage? If so.... Damn
Old Sep 24, 2011 | 04:08 PM
s2000ellier's Avatar
Bounce the rev limiter all day. You over rev by shifting from high to low and going beyond the rev limiter.
Old Sep 24, 2011 | 04:49 PM
LS What?!'s Avatar
I like your Lego stig picture! Bad ass!
Old Sep 24, 2011 | 06:18 PM
Shadow_S2K's Avatar
Former Sponsor
You can mechanically over rev the motor and possible escape damage if you don't over rev it too high, meaning under the 11k rpm zone depending motel year, what year valve springs etc...but hitting the rev limiter won't cause a over rev in it of itself...since its there to cut fuel out before damage can occur.
Old Sep 24, 2011 | 09:31 PM
T-Smac's Avatar
Over-revving is sending the pistons up and down faster than the valve springs can retract the valves.
Old Sep 24, 2011 | 09:36 PM
MegaTRon's Avatar
people with flashpro that set their redline to 8300 rpm. does the ecu still cut fuel at 8300 rpm?
Old Sep 24, 2011 | 10:13 PM
ans2k's Avatar
redline is the revlimt. my redline is at 8500 and my revlimit is at 8500 and recover rpm is 8300.
Old Sep 25, 2011 | 04:06 AM
LS What?!'s Avatar
Which in normal circumstances requires forced mechanical over revving. You can't or shouldn't be able to physically turn the motor past a safe operating rpm.
The reason I asked is because of all the folks that have done this. I've read a ton of posts that say ive only over revved my motor once or twice. I'm guessing they mean mechanically.
Old Sep 25, 2011 | 10:55 AM
jelliotlevy's Avatar
You can never damage the engine if you hit max rpm coming up from below, i.e., accelerating in gear. The rev limiter cutoff will protect you, which it does by shutting off the fuel flow. The danger is mechanical over-rev from above, such as when you inadvertently downshift 5-2 at 75 mph when 5-4 was intended. This forces the engine mechanically to dangerous rpm's, from which the [electronic] rev limiter cannot protect it.
Old Sep 28, 2011 | 01:27 PM
kaotik25's Avatar
^ I have done that at least 1-2 on freeway and once at the track (all by accident). It's not too bad as long as you dont let it prolong for more than 1-2 secs. I did have my engine inspected afterward by Evasive and everything is mechanically sound.
