Over revved ap1 what to check?
I money shifted my ap1, probably hit 10 - 10.5k for 1 second. Didn’t think much of it because the car felt fine but shortly after I’m now hearing an ever so subtle knock and I believe a slight loss in performance but this may be a placebo effect after noticing the knock. The knock is so subtle a person that doesn’t drive an s2000 regularly likely wouldn’t notice but it’s there. How likely is it that I blew the motor ? I’m flatbedding the car to a shop tomorrow, other than the valve train what else needs to be inspected?
I'm gonna guess you damaged some valvetrain components. Likely a cracked retainer(s). Bottom end is probably fine.
Don't turn on the car more than you absolutely need to. If you drop a valve, you'll need an engine.
Tell the tech the same. Inspect the retainers to make sure they're not cracked before running the car any more.
