Overheated..
From factory the motor is around 240 per cylinder. However a motor can still be running good and healthy with numbers in the 150's etc. It's more about having consistency across the cylinders. Granted, the closer you are to 240, the better.
Here's a good DIY for you to follow when doing your Comp. Test..... it'll explain things more in detail and will make sure you do the test properly.
https://www.s2ki.com/s2000/topic/434...ssion-testing/
