Overheating problem
I replaced my stock radiator with an ARC aluminum radiator with a Mishimoto fan shroud today. I checked all my connections and everything checks out fine. As i started driving the car it started overheating after 15 min of driving. I drove back home popped the hood and my engine bay was splashed all over with coolant. Has any one had this problem in the past?
--Louie
--Louie
Here's the sequence:
1. Don't bleed the system.
2. Car overheats.
3. Temps rise, cause mad pressure.
4. Antifreeze steam pops a hose off, or rips it, or whatnot, or antifreeze shoots from under the cap.
5. That antifreeze is all over the hot engine bay, now you got to clean it up, and it's not easy.
2. Car overheats.
1)Bleed the system, there's TWO bleeder valve on this car
2)check the fan operation
3)check for leaks, pressure test if needed
assuming you already have a cap with proper pressure rating, good running hose and connector,etc
