Overheating problem
Old Mar 12, 2011 | 09:18 PM
S2KLR4's Avatar
Default Overheating problem
I replaced my stock radiator with an ARC aluminum radiator with a Mishimoto fan shroud today. I checked all my connections and everything checks out fine. As i started driving the car it started overheating after 15 min of driving. I drove back home popped the hood and my engine bay was splashed all over with coolant. Has any one had this problem in the past?
--Louie
Old Mar 12, 2011 | 10:01 PM
s2cho's Avatar
did your radiator cap come off?
because that could be your only problem....
Old Mar 13, 2011 | 03:10 AM
popopopop's Avatar
Are your fans on at idle?
Old Mar 13, 2011 | 06:18 AM
2003AP1's Avatar
Did you properly bleed it after filling it with coolant? Where is the coolant coming from?
Old Mar 13, 2011 | 08:16 AM
zeroptzero's Avatar
it seems to be a very common issue lately as people change their rads. Improper bleeding procedures and faulty rad caps are the two most common issues.
Old Mar 13, 2011 | 08:53 AM
s2klariat's Avatar
+1
Old Mar 13, 2011 | 12:14 PM
Kirpich's Avatar
Here's the sequence:
1. Don't bleed the system.
2. Car overheats.
3. Temps rise, cause mad pressure.
4. Antifreeze steam pops a hose off, or rips it, or whatnot, or antifreeze shoots from under the cap.
5. That antifreeze is all over the hot engine bay, now you got to clean it up, and it's not easy.
Old Mar 14, 2011 | 05:32 PM
iam7head's Avatar
ONLY?
1)Bleed the system, there's TWO bleeder valve on this car
2)check the fan operation
3)check for leaks, pressure test if needed
assuming you already have a cap with proper pressure rating, good running hose and connector,etc
s2k_4life
May 20, 2015 06:46 PM
S2000_FUN
Mar 16, 2011 12:34 PM
sIIooo
May 22, 2007 07:52 PM
5thelement
Apr 2, 2007 02:14 AM
