Overheating and stalling
Old Aug 22, 2011 | 01:07 PM
arows2k's Avatar
Default Overheating and stalling
Hi guys I wondering if anyone would know what would be causing my car to overheat and stall out when I idle. I had my thermostat, water pump, fan switch and radiator replaced. I also changed my TCT because it was making that horrible sound during idle that is now gone as well. Also I replaced the plugs and air filter. My car runs fine for about 20 minutes then it starts overheating and the idle goes really low and I notice it starts smoking. I also noticed my car had black soot in the exhaust. I looked at my oil and it doesn’t look to have water in there, so I’m not sure if it’s the head gasket. My car is an 2001 with 120k I’m hoping the motor is still ok.
Any help would be appreciated,
Thanks
Old Aug 22, 2011 | 01:12 PM
s2000maniac's Avatar
Looks like your car wasn't bled properly when the thermostat and water pump were replaced. Don't drive it or you will damage the head gasket if you haven't already done so.....
Old Aug 22, 2011 | 03:44 PM
JUSTINTHECOASTIE's Avatar
bleed it properly it should fix the problem
Old Aug 29, 2011 | 03:35 PM
arows2k's Avatar
I ran my car with the heater on and the radiator cap open tilted on a jack for 1 hour and closed it up took it out and im still over heating im not sure whats going on still.
Old Aug 29, 2011 | 04:41 PM
Car shouldnt be tilted at all
Old Aug 29, 2011 | 06:57 PM
s2cho's Avatar
and there is also a bleeder valve that can be opened to let out the air thats really trapped in there. and once you bleed it properly reset the ecu the right way just to be on the safe side to let the car know.
YuriArts
Jan 19, 2017 06:49 PM
Omar46
Feb 26, 2015 08:27 AM
FOSS
Aug 26, 2014 05:16 PM
wildkart
Mar 6, 2014 03:02 PM
9kFever
Apr 25, 2010 04:45 PM
