Overheating problem
Old Mar 6, 2014 | 05:28 AM
wildkart's Avatar
Default Overheating problem
So my issue is, I just put in a new thermostat and bled the system very well even lifted up the front of the car to make the radiator higher than the motor to make sure all the air was out. the car drove fine for a week and a half. and now today i stop at a light and the temp goes up. I get to my work and pop the hood and the bottom hose is ice cold and so are the back hoses for the heater.. so my question is where is the water going?
it seems to be that it is either boiling somewhere and not staying as water to open the thermostat or maybe a bad head gasket.. but i do not smoke or anything to make me think head gasket.
I need ideas. I am supposed to re-tune tomorrow for 700whp.
Thanks.
Old Mar 6, 2014 | 06:44 AM
jordannn93's Avatar
Did your coolant resivour get low on coolant ?
Old Mar 6, 2014 | 07:58 AM
johnzal's Avatar
Make sure radiator cap still has the valve. You might need a new cap..
Sent from my EVO using Tapatalk
Old Mar 6, 2014 | 08:28 AM
wildkart's Avatar
I will check both.. may have gotten low in the overflow. i am going to re bleed the system again today.
Old Mar 6, 2014 | 08:50 AM
baZurk's Avatar
My bet is that the overflow got too low. That seems to dram a lot of air back into the system.
Old Mar 6, 2014 | 01:11 PM
wildkart's Avatar
I hope that is the only problem. we will see.
Old Mar 6, 2014 | 03:02 PM
bobbyrandolph440's Avatar
Also to check head gasket go to autozone and get a pressure tester for the radiator its a rental tool I think our systems are 18 psi pull all of your spark plugs and see if there's any coolant in the cylinder
Sent from my VS870 4G using Tapatalk 2
YuriArts
Jan 19, 2017 06:49 PM
Omar46
Feb 26, 2015 08:27 AM
FOSS
Aug 26, 2014 05:16 PM
ryanswhites2k
Apr 26, 2013 03:18 AM
CHUCKLIDDELL101
Mar 25, 2007 09:33 AM
