P0-411 (Again)
Old Apr 24, 2010 | 03:09 PM
s2klariat's Avatar
Default P0-411 (Again)
Ok ok I know this has been covered numerous times and I've checked everything that I know to check. I've made sure the vac hoses are routed correctly.. the white check valve is pointed in the right direction. Pump kicks on. Checked pump.. no visible holes or damage. But now we get to the solenoid. Air should be able to flow freely through all three of the hose attachment points correct? Well while checking all the hoses and everything for leaks (blowing in one end and seeing if it comes out the other and also checking for holes) I realized that the lower hose attachment point does not flow air at all. So I just want to be sure I'm correct before buying another solenoid
Edit: It's where the hose attaches that leads down to that little air box bolted under the stock intake box
Old Apr 24, 2010 | 06:03 PM
joeILs2k's Avatar
I just had this recently for the 6 time this year already.
Mine ended up being the relay in the air pump system
Old Apr 25, 2010 | 07:46 AM
s2klariat's Avatar
Anybody else? Just need to know if that solenoid is supposed to flow free air out of the bottom hose attachment. If someone could be so kind to check theirs and post their findings I would appreciate it
Old Apr 25, 2010 | 01:37 PM
seoul2k's Avatar
i keep getting this damn code also... still havent been able to figure it out. Thought i did because it went away for a while (thank god it was while my inspection was being done), but now its back
s2konroids
Dec 25, 2011 07:08 AM
camuman
Dec 4, 2008 10:12 AM
lotus7racer
Sep 22, 2008 10:31 AM
sleek6mt
Sep 15, 2006 01:52 PM
